1 - 1 of 1 Posts
Removing the clutch cover is a real PITA. So found some tools to get the bolts out very easily - and in less than 5 minutes.
1 Skewdriver - the right angle head and the 8mm driver socket makes removing the bottom 4 bolts easy.
2 - flexible screw driver extension (HF for $5) and 5/16 magnetic driver bit in you cordless drill / impact for the rest.
I always use antiseize on the threads and hand tighten.
1 - 1 of 1 Posts
