well here is how it works. you can get a 6x12x10 soft sided tool box under the rear corner back seat driver side area, you can also use that yellow area between the two rear passengers to put a soft sided round storage case, there is also a decent storage area under passenger side rear seat, however caution there as its the battery box so I don't use it. I also put a long rolled up tow strap inside the spare tire rim, below the jack system. so there is some, you just have to figure it out and make use of what you have. very little to no room under front seats.
