1 - 18 of 18 Posts
Has anyone fitted the Max front brakes on a 2 seater? apparently the Max front brakes are larger...If so was it just a case of swapping rotors and the carrier for the caliper...
Interested in this as a lot of my riding is high speed and long distances on public roads so better brakes would be good.
I 2nd the motion.
Sent from my SCH-I545 using Tapatalk
will this mess with the brake bias?
Doubt it because my rear brakes always lock up before my fronts. The brakes now are the same size front and back. From the guys that I've spoke with the Max front brakes are a big upgrade.
Discussion Starter · #6 ·
Thanks for the info, next time I speak to my dealer I will ask him to price up the parts.
Thanks Alex - So do you know exactly which parts are needed to other than the larger rotors obviously...
Discussion Starter · #12 ·
I'm not 100% sure but you can't buy the bracket separately from the caliper so I haven't really looked for a difference.
Thanks, I will have a look at the caliper and bracket on mine this weekend and see if it's possible to make up a bracket to work with the larger diameter discs.
Yea, i just looked at the parts manual and they only sell the caliper as a complete unit. List price is $212 per corner and the rotors are $38....
Im going to try the BRP race brakes on mine in the next couple months and see what happens
We will putting the BRP race brake kit (only avail to BRP team racers at this point) on the front which are 260mm rotors, and using the front Max rotor/caliper set up with an aftermarket master break cyl (with built adjust brake bias) and use use the Max front rotor/caliper (215 mm) on the rear..
Reactions: AReed
mike take a look at the link, i have used one before and it worked really well. made it easy to do all the lines. has dual or single mas cyl inputs and dual front out etc etc. take a look.
Distribution Block - Adjustable - Black
1 - 18 of 18 Posts
