I have a XRS in the shop and this uses the factory yellow lid. I assumed the base model has the same lid.Alex, are you fabricating a lid? Or does the max have a cover or trim piece that closes it up?
This is the exact feed back that I need on products like this.I would like that to, however I think a few small holes should be drilled into each side as that area gets hot, need a way to have some venting, not much, but some. tools and stuff goes in my area, would not put anything sensitive there. of course I guess you could sell them as is, and we drill in any holes we may want also, this way its one size fits all...we could mod it with holes if need be.I like it. should be worth a hundred at least. just need to make sure that metal side don't get to hot as it could burn your leg, need to test it and make sure its not crazy hot after an hour long ride.
If the engine wasn't there I would do it. I may look into that.Build something insulated to keep 4 cans of pop, beer, or water cool.
I'm using the existing bottom of the storage compartment. Without being about to flush the hot air out I don't know if the double wall would be too effective.I don't have a MAX but I know about the engine heating issue on the 2 seater….would you possibly be able to make it with a dual wall bottom in it to insulate the contents from the engine heat?
They do take up space big the last thing I wanted was for the whole thing to rattle around and make noise. I know what slots or holes you're talking about where it mounts but I don't think I could have the tabs stick out far enough to hold it but also make it possible to get it in, plus the rattling issues.Hi Alex,
It looks to me like there is a lot of space that is taken by the rods that are connecting the two sides. In seeing your prototype it gives me an idea to just cut two pieces of aluminum with tabs that could clip into some slots that could be put in the existing plastic with a dremel. I would also want something to be attached in fairly well to handle lots of bumps.
Waylon
