Went riding last weekend and on the last day I was just sitting in some water with my bike just deep enough for the belt housing to be under. When I went to pull out it was slipping bad, checked the drain port and sure enough had a good bit of water in it, to my surprise the drain port was this cheap little rubber/plastic grommet with a wire type piece to hold it on. My thoughts is its that leaking by but im not sure it could be anything, my question is anyone having issues with the belt housing leaking on the back side or anything else? Im fixing to do a clutch on it so im prolly going to pull the belt housing and seal the back side possible get a new gasket for the middle section and figure out a better way of making a drain port, just wanted to see what peoples experiences have been. thanks
