1 - 20 of 34 Posts
Hey guys, first post here. Just picked up my brand new maverick X3 a few days ago. Super excited as I’m finally getting back into riding after 8 years!
Anyway, I am interested in installing a Switch-Pro 9100 in the x3. I have one installed in my Tacoma and I love it. The only issue I seem to be running into is the mount plate. It appears the only options out there are custom made ones.
So, I came across this...https://www.sxsperformance.com/ssv-can-am-maverick-x3-dash-mounting-panel-for-the-mrb3-bluetooth-media-controller.html
do you think that it would fit the SP panel?
my second option is to buy a ruggedradios panel and modify it a bit to make it fit. I would also be using the Switch-Pros as the starter button.
For or those that have the SP, can you post pics of your mounting solution for the panel?
Discussion Starter #4
Thanks for the replies guys! I am actually considering mounting mine exactly like yours sandfreak. I’ll be purchasing the rugged radios dash panels as well. However, rugged radios sells block off plates. I was planning on mounting the switch pro on the RM-60 block off plate since I only plan on running the intercom setup.
I used the mega steering wheel mount and just drilled new holes works great and right where it need to be and out of the way ..
CF2DF788-1AB0-4170-B472-CB558FC190A5.jpeg CF2DF788-1AB0-4170-B472-CB558FC190A5.jpeg All I got but should help it’s been working well
Official Site Vendor
I have Switch pros, Rugged, SSV, and the Mega mounts. PM on any of these items. I like the mount over the starter button with the Rugged Radio plate. These are all very creative mounting solutions.
Discussion Starter #12
Just ordered the mount I originally linked in my original post. Planning on mounting my Switch-Pros unit there. Based on the dimensions, it should mount right up and look factory...hopefully lol. Im also planning on relocating my factory battery to underneath my passenger seat. I will be upgrading to a odyssey 925 battery but I will still only be running a single battery setup. The factory bitterly location is where i will mount my Switch-Pros control unit as well as an auxiliary fuse box.
117B3A14-D9AB-4FE7-BAD3-1FBA6612EDD8.jpeg 95F95610-955D-442B-9AB8-BDFF3A3C8F0A.jpeg
Discussion Starter #13
E4B83297-BA30-4465-80E0-816819F46918.jpeg 636DACA9-688A-49E8-81C2-AE5B017CA4D8.jpeg E49A4DEA-2F75-4BE7-8885-FC65320BB331.jpeg
Just got my switch pros. Mocked it up inside the SSV mount. No drilling was needed at all. It will bolt right in to the SSV panel/mount. I’ll get in mocked up in the car tomorrow and post pics. We will see how I like the position of where it’s mounted.
Discussion Starter #16
ACE03C10-41D8-4871-8322-469548920528.jpeg BE222C4C-7E38-4D42-A393-BB8FB55E2CAE.jpeg 5C5C677A-9B37-4861-B7C3-690F471B598B.jpeg
Here it is is installed in the car. I had to slightly modify the plastic base plate. Not pretty but you wont see that part when mounted.
I actually like the positioning of the unit. I can hit the switches easily with our having to reach for them and they are at eye level so I can just glance over to see what’s on and what’s not
My switch pro control unit fit in the cubby behind the passenger seat along with the OEM battery and a second battery.
Discussion Starter #18
I’m mounting the actual control module under my
passenger seat along with an auxiliary fuse box.
This whole panel is getting mounted under my passenger seat.
1 - 20 of 34 Posts
