1 - 5 of 5 Posts
Rolled my X3 Max DS and now Check Engine light is on and in limp mode. Any way to reset ? Was told there is a Sensor between the rear seats that if broken can cause the car not to read the air intake properly. Any tips on repairing that sensor?
The only sensor between the seats is the seat belt sensor. Did you disconnect the battery yet?
I had same thing happen to mine. I have no active faults but chk eng msg and lite. Had battery disconnected for a week. Still got lite and msg. Dont think disconnecting battery fixes anything?
There is a code for improper shutdown. And also for belt slippage. Im thinking that is wat caused my light. When i get home i am going to connect mine to my CANDOO tool and kno for sure. But if your shut down that will cause it
Also chk the hose that connect the wastegate to solinoid. For some reason the solinoid barb broke when i tipped over on side
1 - 5 of 5 Posts
