1 - 20 of 31 Posts
New to the forum and i need some help. I have a 2016 Maverick turbo and it wont start. When i turn the key all lights and dash come on and it recognizes the key. When i push the start button the starter relay clicks once and the lights go out but the machine wont start. I have load tested the battery and made sure it was fully charged to 12.8 volts, i replaced the starter relay, replaced the starter. I have no clue what else it could be. It doesnt try to turn over or anything. Check all fuses at the fuse panel and swapped around the relays there. It ran fine when i parked it. Any help would be awesome! Thanks
Administrator
Make sure both ends of the main battery cables are tight....check the battery side first.
Battery is brand new and i had it load tested. Cables are tight. When i try to start it, it pulls a load from the battery. The last time i tested the battery while starting the machine it would drop to 8-9 volts when i push the start button.
Is the motor locked up? pull the clutch cover and make sure the motor turns over by hand it sounds like the solenoid is working pulling a load but the starter wont spin for some reason.....
Reactions: Mudskipper
Ill have to check that. I sure hope its not, the machine only has 30 miles on it and it ran great before i parked it.
It sounds a little like a bad cell in the battery I dont think it should drop to 8/9 volts ,maybe try hooking up a set of jumper cables hooked up to yr car or a large spare battery, My car did the same thing when I forgot to plug my tender in , when I went to start it put the key in hit the start 1 everything turned on hit the start button to start it small click and everything shut off, also check your ground to the frame, if you try the jumpers and get the same thing try putting the ground cable clamp onto the frame or engine if it starts you have a bad ground
Discussion Starter · #7 ·
So i havent had a chance to pull the clutch cover and belt off to make sure the motor turns and isnt frozen. But i did disconnect the cables from the battery and hooked them up directly to my booster pack to bypass the battery. It did the same thing when i tried to start the machine. Just a single click from the starter relay and thats all. One night this week im going to try and turn the motor by hand to make sure it turns freely. Thank you everyone for the help so far. Hopefully i can get this figured out soon, riding season is coming quick
Sounds like a bad ground. I tried jumping a buddies car years ago when he killed his battery at night and it would not even do shit. It could still be weak on power and a ground.
Discussion Starter · #9 ·
Im thinking it has something to do with power or ground or maybe a sensor. It ran fine when i parked it. I had the battery load tested and napa said it was a good battery. My next steps are to remove the belt and spark plugs and turn the clutch to rule out that the motor is seized. Then im going to try and hook the booster pack up to it and put the ground from the booster to the motor and see if that helps. If that works then i know its a ground somewhere. Im doing all i can to not bring it to the dealer and spend $$$ haha
Something is drawing the power because when i push the start button the battery goes from 12.8 volts down to 8-9 volts. The machine only has 30 miles on it so i doubt its something major. Hopefully tonight i will be taking another look at it.
It has to be either the battery cables not making a good connection and either end, I suspect ground side, or the battery is bad, my suspicion.
I have jumped stated my old Maverick from a car before. I would find a way to try and jump start it from a box or car. You can also aid the ground side of the battery with a pair of jumper cables from the ground side of the battery to a ground point on the chassis.
This is something very simple. Very unlikely the motor is seized from sitting. Tim
Administrator
Absolutely....hope the OP follows through with checking the other end of battery cables as post #2 suggested. A loose ground and/or some slight corrosion can wreak havoc as would a poor connection at the starter could.
Before you go crazy just get a set of jumper cables and go from your negative and to the frame or engine get a good connection and if your batt is good it should start fine , on our heavy eq, dozer.scrapers they have a batt disconnect switch its basicaly a cut out switch on the negative cable they go bad I jump from the ground terminal to the frame they fire up and I know its a bad switch , its better to check the easy quick things before pulling stuff apart
Discussion Starter · #13 ·
im thinking it is the battery too. Even tho i have it tested at napa and they said its good, i still think there is an issue with it. All the cables, connections and grounds look great plus the motor turns over with ease when I took the plugs out and turned the clutch. The machine looks brand new like it just came off the sales room floor so there is no corrosion or rust on it. It has 30 miles on it and has been garaged its whole life. Depending on when i get out of work tonight im going to try jump starting it with my truck instead of the booster pack. Or i might just go down to the dealer and purchase a new battery and try it. Like I said the starter solenoid/relay clicks once when I push the start button and once in a while it will make a whining noise.
I tried hooking the battery pack directly to the power and ground cable at the battery but not connected to the battery to bypass the battery and see if that would work but it did the same thing.
It has to be something minor because it ran when I parked it
Discussion Starter · #15 ·
no luck yet. I have tried jumping it from my truck. Both connecting the jumper cables to the battery and also by disconnecting the cables from the sxs battery and connecting the jumper cables directly to the sxs cables to by pass the battery to rule it out. still no start or anything. i connected a lead directly from the battery to the motor to insure that the motor is ground and still nothing. i bypassed the starter button and that didnt help.
I am completely lost right now. I have bypassed everything i can think of and replaced the starter and relay with no luck. The battery was tested both at napa and with my load tester and the battery is good. I dont know what to try next. Would it be a fusible link maybe?
im going to work on it some tonight and see if i can come up with anything else. if not i think its time to bring it to the dealer and have them look at it.
Use a multimeter ground on the starter or engine then try to crank the engine to see if you have voltage at the starter post.
Sent from my SM-G930R4 using Tapatalk
Discussion Starter · #17 ·
I have tested to see what the voltage is at the starter and its the same 8 volts that is going thru the relay. You can feel the starter want to turn but it doesnt have enough voltage. I also test for drop on the starter post at the post and on the casing and everything reads like it is suppose to. Even when i hooked my truck up to battery cables it would still draw around 8 volts and that was bypassing the sxs battery and having my truck running. Something is either pull a large draw or something in the ecm or other electronics is messed up. No matter what i hook up to the machine, it draws 8 volts. Meaning it will read 12.6+ volts and when i push the start button it drops to around 8 volts.
Administrator
Replace the + battery cable from the starter post out. That cable lug that attaches to the starter post possibly is corroded, but probably had a bad crimp from day one.
The voltage drop to 8 volts signifys high resistance in the starting circuit.
You have replaced the starter and relay with no change... let's assume they are OK.
You have verified the negative continuity by the negative jumper cable from your truck battery to motor.
It is highly unlikely you could have put the positive jumper cable from truck onto that dinky starter lug to bypass the + starter cable and have a good contact.....and you didn't mention doing such.... only using the other end of said cable.
You stated the cables "looked good", but a bad crimp can't always be seen by eye .. only when a current load is applied will it rear it's ugly head.
You're running out of options up to this point IMO. Good luck.
Discussion Starter · #19 ·
this is a shot in the dark but worth asking. When i did the procedure to retrieve any codes on the dash it revealed a p0562 which is a low voltage code. Would that code put the ecu in a limp mode and not allow me to start it or something? Or could that be something with the voltage regulator that again is preventing me from starting it? If it could be the code, is there a way to clear it?
LBR i will check all the cable connections and crimps today and see if i find anything. If i can't figure anything out this weekend then i am bringing it to the dealers this week because im tired or trying to figure this thing out haha
This is a realy stupid question but you do have it in park or in neutral if in park rock the car so it locks in I scared my self a couple times because it wasn't locked in park with my tune it doesn't mater anymore but when new and before I realy knew about it I had a couple ohh crap moments
1 - 20 of 31 Posts
