1 - 20 of 108 Posts
We do have the kit produced and running well. Please call our shop for information as I will likely not be able to get on here and answer questions, but I will try. We hope to have information on the website within days.
We will have the production kits for delivery next month.
Here are a few highlights:
Mitsubishi OEM Turbo
CP Forged Low Compression Pistons
Modified ECU
Larger injectors
Maintains Stock Mufflers
Air/Air Intercooler
Boost Gauge
**** Clutch replacement is required.
ECU modifications:
Powertrain Protection = off. No Shaft saver NO SPEED LIMITER
rpm raised to 8500 RPM
Knock control still active and less sensitve for full power and still protect the engine
ECU errors like plenum pressure fault eliminated
cooling fan activation at lower temp.
optimized air temp and engine temp set points
low gear full RPM until 8500 RPM, but engine torque and power limited by max throttle opening
Reverse riding speed limit 30 kmh and without seatbelt 20kmh.
Trey
MCX-USA
928 846-3505
I'd like to see some videos
It's prolly a 16g eclipse oem new turbo
That's Pretty Impressive... 0 - 60 in 5 Seconds vs 10 for the stock machine... A+++
Hmm Dyno Tested on 11/26/2013.....?
can't wait to see someone with this setup! Need some Guinea pigs to try this out first :saint:
Reactions: chevycraig
Guinea up heavy...lol
Sent from my SCH-I545 using Tapatalk
I have a deposit on a kit. I run mcxpress on both my nytro and apex and they are turn key and go. I am sure this will carry over into the maverick kits. I would think Erik over in Sweden has been testing/tuning this kit until he's quite confident in its performance. I am thinking clutching will be the only thing involved in tuning this kit
Reactions: rmeeks24
As I read the first post this is exactly what went through my mind lol
Sent from my SAMSUNG-SGH-I747 using Tapatalk
yep....the wife is tolerant but not to the point that I can drop $5K on a turbo setup....that would take a lot of "Chowdering" to get that to fly.
Reactions: rmeeks24
1 - 20 of 108 Posts
