Took it out this weekend with the boys. Had a great ride until someone noticed my wheel turned in. Bent upper arm, but the damaged never stopped there. WEAK tie rods. I will tell everyone to through those things as far as you can and get some amped up billet or solid steel. Still damage was coming in. At this point i am being dragged out of the bush. Also broke an axle being towed out. Ended up just leaving it there over night before more damage would come out of this. Pick it up the next day, was able to drive right in the with pick up and trailer to grab it.
Now i know most of you guys ride dunes and trails. I am from the great white north not much for dunes, but lots of trail riding. I am not pussy footing it by any means never hit hard bumps at high speeds that is. It looked like the problem was a small weld on the UPPER ARM. That was the bend point from repetitive bumps going down trai and everything else that got broken was the drive back out. I have not had this thing that long. I am going to see if they will warranty those parts. Other then that I love this unit and is it ever a blast to ride :cool2:
