I finally got on the ball and started getting this maching together as I have to have it all done by Thursday night this week we are heading to the coast. I performed the 10 hour service using the exact weights in the front and rear differential which was the same weight and the heavier weight as required in the transmission, all synthetics. Also used Royal Purple 5/40 in the engine. Got the doonz tires and douglas wheel setup on. Installed the sport low switch which makes a huge difference for sure. Installed the Turn Key Black roof, Installed the EMP Full front windshield polycarbonate coated. Installed a Viper 4K Winch using the EMP Winch bracket with amazingly enough left enough room for the Turn Key Front gusset still and the Turn Key Front Skid Plate, which took a little modification, but not much to make work. Installed UTV Rear gusset and hitch bracket, Greased all the zircs. Still have to get the Super UTV Power steering installed, as you can still see its in the box, and waiting on the 20 inch Rigid Industries light. Going to be a push to get it wrapped up but things are going well... Here are some progress pics......
