1 - 7 of 7 Posts
TurnKey UTV Can Am Maverick GPS Dash Panel. All TurnKey UTV products are made in the U.S.A. using only the highest grade materials available. Our new Maverick GPS panel allows the user to install a Lowrance HDS-5 or a Lowrance Elite 5 GPS system into there vehicle. Our design relocates the four factory switches, ignition key & start button. Panel is made from CNC cut heavy gauge aluminum. Our unique mounting brackets allow for the removal of the panel without having to remove the plastic by simply unscrewing the four mounting screws. Panel comes in two standard powder coated colors, Maverick yellow and satin black. GPS panel comes with all mounting hardware necessary for installation. Cutting of the factory plastic panel is required.
MSRP: $84.95
Forum member price: $80.71
Link to product on our site:
http://www.turnkeyutv.com/turnkey-p...gory_id=53&flypage=flypage.tpl&product_id=119
How is the signal strength with the gps mounted like this and your aluminum roof? Or does it need an external antenna?
Discussion Starter #6
In stock ready to ship. We designed and built the Maverick / Commander GPS panels starting in December 2010.
You may want to check your web site. It appears down right now...
1 - 7 of 7 Posts
