1 - 5 of 5 Posts
Are you on the sticky green ? What the heck are you talking about ?? What is turbo fluttering ? Are you possibly talking about a blow off valve ? BOV ?
turbo flutter is caused when you chop the throttle on a car without a blow off valve BOV
what is happening is the turbo cavitating because the boost psi has no place to go so it back up
and out the turbo intake
to here it you need to here it thru the filter housing (not much) so the best way to here it is with a aftermarket intake that is up high with a simple filter on the end...so no canister
also turbo flutter is not desirable because it can actually damage the turbo at higher boost levels
to get the whoosh from a turbo you need to install a BOV
but it eliminates the flutter
Sounded like he was wanting turbo flutter ? BOV’s really are great ! (Besides the cool wooosh sound :)
1 - 5 of 5 Posts
