1 - 12 of 12 Posts
Hi guys. I remap an ecu of maverick x3 rs 2019 with maptuner. installed all the stages on ecu. And nothing happened. It just revs up to 7700 max. Does anyone know what is the issue?
Im really appreciate if anyone have some advice
FYI...You may want to do a formal introduction quickly before this gets move to member introduction, since this was your. 1st post
Barbara
Sent from my moto z4 using Tapatalk
2020 X3 X RS RR
RPM is a clutching issue as the tune likely increased the redline RPM but the clutch is in need of tuning.
And you can only load one tune at a time not all tunes are in the ECM.
ok so you loaded all the tunes...
the maptuner holds all the tunes
so what tune is in it now?
and you can only have one tune in the ecu
what were your rpm before you flashed the ecu? 7700...lol
Discussion Starter · #8 ·
I tried all the 1, 2 and 3. Not all at once. And nothing happened. Yeah it was 7700 before flashing
Discussion Starter · #9 ·
I meant that I tried each one of them and nothing changed.
Stage 3 is now installed.
Discussion Starter · #10 ·
What should I do with the clutch? They are nothing mentioned in the tune specification. They only mentioned that I should have a decat exhaust. Which I have
first try adding more pre-load to the secondary
then log a run and see what you get for boost
1 - 12 of 12 Posts
