1 - 13 of 13 Posts
Since there are none to be found I decided to make some for the front today.
Installed the lights while I was at it to.
nice !
That should work good !!!!
Discussion Starter · #7 ·
Looks good what did you make them out of?
I had ordered the extentions for the XP 900 and only put them on the front and used the rears for the front of the Maverick.
There was a guy selling them on ebay.
Discussion Starter · #8 ·
What size lights are those?
They are the new 6" with the center 4 LED's being spot and the outer 4 on each side are Flood. Best of both worlds for my kind of riding.
If you order the lights get the wire harness it is well worth the 25.00 comes with a relay setup, however I did not use the off/on button I used a toggle switch because when off it has a red led light that stays on and I was worried it would run the battery down if not ran in a week or two.
Just to make sure I understand this. The flares are XP 900 rear flares. Did u have to make any mod's to get them to fit the front
of your Maverick.
by the way they look great. Looks like a must for mud'er.
Discussion Starter · #10 ·
The guy sells a set for all 4 wheels for the xp900, I used the fronts on the xp and the rears on the front of the maverick. I took a old bolt cut the head off put it in a drill and spun it on a bench grinder to put a point. Screwed it in one hole with about 1/4" of the point sticking out then used a mallet to tap the flare to mark the bolt hole locations one at a time.
Up by the headlight I used a stainless screw since there are no screws in that area.
I also use a heat gun to form it around the headlight area and to bend the bottom flap back.
Just incase you wanted to know
your roof looks cool. just ordered utv's. wish i wud of seen that one 1st.
Wat roof is that.
Discussion Starter · #13 ·
its made by audioformz
1 - 13 of 13 Posts
