1 - 5 of 5 Posts
How do I install it? directly to the battery or to front/back fuse box
Dont care if power on start or not
I haven't installed accessories myself and I'm a bit lost
Just choose either the always positive post or the accessory post. No need to run it all the way to the battery.
You want power all the time. Run it to the bus bar in the center tunnel. Maker sure you hook the positive to the post that is constant power. The accessory post will turn the gps off when you turn your maverick off.
1 - 5 of 5 Posts
