Lower rear,front arm mount...
12K views 15 replies 7 participants last post by  mrtosh
Who has removed the plates and did you have to cut them? What did u use instead? I think my one bolt is bent. Front tire still wonky after both arms and all bushings replaced.
#3 ·
Get the steel sleeves cut on a lathe and install 1/2" bolts along with a gusset kit.
Get a gusset kit like the one from TMW, all the a arm bushings shoulder up to gusset instead of paper thin frame metal.
Makes for a nice tight front end.
If you're ambitious, throw some 1/2" bolts in the rack while its apart.
#4 ·
What sleeves? The ones in the bushing of arm, I have CT race works gusset kit already s d had it when I clipped stump. I replaced upper and lower arms and my tire is still cambered out at the top just slightly. And when i looked at lower rear bolts the one looks like it's slightly bent. Think of just useing a plate to tie them together where factory one is on the head of bolts. But have mine with both bolts passing through. Does the factory plate that's around the head of bolts. Is that welded to frame or bolted?
#5 · (Edited)
I removed the plate that retains the lower rear a-arm bolts by drilling out the 2 rivets in order to remove each bolt and retaining plate. It is the only way to remove the bolts unless someone has found a better method. I reinforced the lower a-arms with the new plates from TMW as shown in my photos.
#7 · (Edited)
Yes. Just drill out the 2 rivets and the thin plate can be removed. The bolts can be removed after you remove the plate of the lower a-arm. I had 3/8" UHMW custom cut to close the small area of the skid plate that I dremeled out.
#9 ·
The TMW brace is the best one I have used.
Covers all the holes.
The pics I put up with the 1/2" bolts use a different brand brace. I had to weld tabs on the upper rear a arm mount holes, as the frame was wallowed badly at 2800 miles.
That's the only hole that brand brace kit didn't catch.
Had to pull the rack to weld in the tabs.
Noticed excessive positive camber on pass side, tore it down, found the issue.
#13 ·
Sandhoon did you figure this out? I have almost an identical issue. I have the CT gusset and clipped a tree stump bending both my upper and lower A arms. It bent to where the wheel was extremely cambered out. With new a arms and new ball joints I have some camber, but now it's slightly the opposite direction and cambered in at the top. I'm thinking either bad A arm bushings or possibly a damaged knuckle. Did you have any luck?
#14 ·
To get those 2 lower a-arm bolts out just notch out the skid plate a little...doesn't take much.
