1 - 3 of 3 Posts
Has anybody swapped out the rear lower a-arm bolts, so you can remove one instead of having to remove both?
I’m pretty sure in the stock setup you only have to remove the plate that ties them together. You can replace one at a time. You only have to do both if you are using a gusset kit.
Discussion Starter #3
I do have a gusset kit. I figured it out. I cut the tabs for the bolts. Now ill just have to use a wrench to hold the bolts while tightening them back up.
1 - 3 of 3 Posts
