1 - 1 of 1 Posts
The Lonestar Racing MTS suspension kit for the Can Am Maverick X3 is +3" wider per side in the front and +2" wider per side in the rear with stock wheel base.(based off the XRS) The kit will come with high clearance front a-arms, high clearance rear trailing arms, radius rods, tie rods, radius rods double sheer gussets, rear mud flaps, radius rod plate, front sway bar links and all necessary hardware. It will feature 24" of suspension travel in the front and rear.
  • Available with or without LSR 300M axles (uses stock cv's)
  • Uses stock length XRS shocks
  • 7/8" uniballs with 300M pins in a-arms
  • 5/8" heavy duty rod ends in radius rods
  • Made from 4130 chromoly tube for superior strength without the unnecessary weight of boxed arms
  • Double sheer front sway bar mounts
  • Race Tested
  • Must use XRS shocks
    Available in bare steel, gloss black, flat black, gloss white, silver metallic, candy red, candy blue, can-am yellow and more.
    [h=1]Lonestar Racing Can-Am Maverick X3 MTS Suspension System[/h] lonestar-racing-can-am-maverick-x3-mid-travel-suspension-1__47745.1534197054.1200.1200.jpg
    lonestar-racing-can-am-maverick-x3-mid-travel-suspension-2__12928.1534197055.1200.1200.jpg
1 - 1 of 1 Posts
