Hit limp mode today. Did it twice in a row after rebooting. Code was P0167. Not finding anyone having mentioned this code previously. What's the thoughts on bad fuel being the culprit? We added half a tank of "ethanol free 90" from a station that probably does not sell much of that flavor. Not blaming "rec fuel", but do suspect this particular batch.
So, about 80 miles into 110 mile run. In the mountains of WV, about as far from truck/roads, was turning around and it sputtered a bit and then limp mode. Shut it down, did a quick visual to see if a stick or something knocked a connector but no dice. Ran OK for a couple minute and then back into limp mode. Pulled the code and then looked close at the O2 sensor (all visually good). Cleared the code and took off after 5-10 minutes of futzing with stuff. Was good to go for the remaining 20 miles, though I was being slightly easier on it.
We were 1/3 into the tank of rec fuel ( 4 gallons) at the time. That was the only item; temps were fine (80) and was not overly muddy/wet.
Code is P0167 Heated Oxy Sensor Heater Circ (bank2, Sensor 3)
The wiring/harness to it were snug, again no visual. Guess it could be a genuine failing sensor. Probably need to order just to have it "in case".
2018 Mav Trail 1000
2018 Mav Trail 1000
