1 - 3 of 3 Posts
Can AM Maverick Trail 1000 DPS
Ok I have a 2019 Maverick Trail biggest issue Clearance! I get high centered way more than I should here are my limitations: I haul it around mostly in my fish house and I cannot go any wider tires already rub on both sides. I would like to keep factory wheels just bought new tires. Largest tire size I can use is 26x9x12 which is what I have. I only have a max of 2in higher I can go and still fit
Discussion Starter #2
has anyone tried the Super ATV 1.5" front and rear A arm offsets? and does it raise the under carriage at all or just adjust the A arm higher?
Also looking at the Super ATV 3" lift but idk if it will raise it too high to get into my fish house. has any one tried it? if so how did it affect your over all height to the roof?
open to other options other than Portals not looking to spend that much.
With our forward arms, you can run up to a 30" tire which should get you about 2" more ground clearance than your current 26"s.. The arms are arched for more clearance in the front too. That's a good start. From there, you can always add the 3" lift if you still need more.
1 - 3 of 3 Posts
