LED Replacement Headlight Bulbs
1 reading
47K views 57 replies 26 participants last post by  onkyo
I had some replacement LED stock-style bulbs in my old Yamaha Grizzly that I got off ebay for 50 bucks which were extremely bright. Kind of a flood beam, but better than stockers none the less.
Has anyone tried this type of bulb in the stock Can-Am projectors? I would like to avoid the trouble of HID kits, never been a big fan of them since I had some from DDM tuning on my old truck. The only problem that I had on the Grizzly was that the stock bulbs were combo high/low, and the LED's were not so I had the same lighting in high and low. However, I think the Mav's have two separate bulbs for high and low so this wouldn't be a problem. I believe I read somewhere that both bulbs are 9005 but with different Wattages.
Any ideas?
I'll add a light bar eventually, but would like to start with the stock headlights.
#3 ·
Our search function sucks. I don't remember reading about led replacements, just hid. I'm interested as well!
Reactions: amc019 and 07XLN
#4 ·
I bought a decent led light bar for 118.00 shipped off Amazon and it washes out the stock headlights , if the bulbs were 50 per pair , you're basically there with all 4 . Just a thought. I was watching one 42 inch light bar and the other day it went on sale for 105.00 shipped. Just FYI . Tim
#9 ·
I'm interested. I would like to find some LED replacements. I just don't have room for a light bar. Can't mount it under the roof due to line of sight and do to much woods riding to mount one up top. I do have some LED spot lights that I am going to mount on the front bumper though.
#10 ·
Boy they are proud of these led conversions! 600$ to replace stock lights, you can buy some rigids that'll out power them hands down.
I've had good luck with my DDM HID's and for 200$ guess that's where I'll be headed, can still add a light bar for 400$ and have way more light
#11 ·
Can you run a light bar off of your accessory plug behind the dash or should you go through a relay?
#16 ·
Is 50$ doing 35 watt in all 4 lights? (For some reason I had 100$ in mind a set) if you put 35w in all 4, do they light up enough to not need 55 watt?
#19 · (Edited)
Thanks for the advice, I worried about the heat as well but seemed to have no problem in my ATV but worried on the max.
Did you use the "extension cables" to get the ballasts under the hood or was there enough wire?
on a side note, just notice that DDM Tuning 35 watt HID kits are 30$ a set!
Reactions: kessler89
#21 ·
They're def worth $30/set I put off getting a light bar all last season only because I thought they did so good, I bought a lightbar cause I'm greedy with lighting lol
Use the o rings off the stock bulbs, they seem to seal perfect
#22 ·
I had "80" watt bulbs in my Grizzly lights and there were no heat issues.
In general, I think they run a lot cooler than HID and Halogen lights.
Here are some of the bulbs I have been considering, and is the same ebay seller that me and many other guys on the Grizzly forum bought.
80 watt- 2 x 9005 9145 High Power 80W CREE XB D LED Fog Driving Light Bulbs White 6000K | eBay
30 watt- 9005 Fog Driving Daytime Running Light CREE XBD White High Power 30W 720 LM LED | eBay
High and low beams, respectively.
#24 · (Edited)
You're wasting your money if you care about actually improving the performance in your lighting, those "80w" led bulbs only put out 1-1300 lumens that's about the same if not less than the stock 9005 bulbs
35w DDM Tuning Hid's put out 3200/3500 lumens PER BULB, slap 4 of them in there and you've got roughly 13,000+ lumens out of the stock projectors for less than $100
Edit if you want the most light shoot for the 4300 or 4500k color any higher than that and you're just throwing away light for blue ricer hids, I'd say 5k as a max cause my buddy has 5k ddms and they seem to do pretty good, I'm running 4500k
#28 ·
�� anyone try them?
Still leaning on HID seems tried and proven
#29 ·
I installed HID's and ended up taking them out. They had lots of hot and cold spots, where the stock bulbs had even light without any hot spots. They were cheap Hid's and i dont know if that makes a difference . I also noticed I got the bulb in but not correctly and just that little but of slightly crooked made hot spots and cold spots. I question maybe the projector lense is very sensitive to bulb placement and maybe the fact the light is basically running perpendicular in the hid to the filament on the stock bulb. IDK. JMHO . Tim
#32 ·
Anyway..
What affect do the "projector" lenses have on normal light bulbs exactly? I wonder if it would channel the flood pattern of these LED's to more of a narrow spread better suited for long distance visibility.
As I said before, I'm not a fan of HID's, they take time to warm up, don't like being bumped around too much, and get really hot. And how long the ballasts will last is always anyone's guess where the LED's are plug and play, and then you don't have to worry about em again.
#36 · (Edited)
I had the LED bulbs in my 700 grizzly also-way better than stock. I ran a light bar on my rad relocate kit so I wasn't worried about them being flood only pattern.
As far as the hids go I went with them on the maverick. I ride with Kessler89 and his seemed to last through quite a bit of mud/water/vibration on the xmr before he swapped them over to the mav. That sold me on the DDM tuning setup I now run in my own machine.
I might get some LED flood bulbs for the low beams to experiment after I get my light bar bought. But for your money the HIDs are the ticket.
As far as light bars and relays go: its a matter of opinion. I personally believe you should use one for a "piece of mind". Keeps from overloading a circuit like the cigarette plug-u might need to use it at the same time for something. Changing a fuse isn't a big deal if it pops but kneeling down to pop open the fuse block, in mud or slop for some of the mud guys, might be an issue.
#33 ·
I keep reading about hid non durability and sit back and laugh, my lows came from my xmr so they're pushing 2 years old now, they spent a ton of time under water, with outlaw2s slinging everything under the sun at the housings for a year and another year in my maverick no issues
I guess I do math different and have factory freaks in my hi/lows and the set of ddms in my car still going strong 5 years after I installed them
Dumping 3x more light than a led bulb for less money
#34 ·
i agree! When I first started using DDM I was skeptical and have since put them in 3 wheelers as well, but I don't have any prolonged warm up time and my hi/low kit works perfectly after 3 years in my quad. If LED bulbs were economical and could produce the light that HID's did I'd consider it, but just can't see spending 600$ to convert my max when HID are 60$
