Most double rows use 3W, whereas single row uses 5W LED's. Spot is for long distance, flood has a wider beam, and combo combines both. I think the combo cuts the forward distance a little shorter.
You can get single row bars with 10 watt LEDs instead of the 5's. With the 10 watts you have a lot bigger lense so you can get a lot more distance out of them
