1 - 7 of 7 Posts
Ok looking for a LED Light Bar, LED accent lighting and LED whip. Which ones would you guys recommend? Do any of the LED Light Bars have accent lighting? I thought I saw one the other day but can't seem to locate it now.
First question you need to ask yourself, seriously is -
How much do you want to spend? IMO, Rigid has the best stuff out there, backed by a lifetime warranty. I run their 40" bars on both my X3, and my Wildcat. No complaints.
Whips - I run Tribal Whips, once again, not exactly cheap, but they have never failed, and I believe they have a lifetime warranty too.
You can buy cheaper stuff, that will be almost as good. Just depends on your budget.
Got the 42 in Mictuning Led light bar with EMP mounting brackets and wiring harness with rocker switch for $122 on Amazon. Works great
I just bought a pair of Rigid Dually SS pods, 2- 10" Rigid single row bars for the shock tower and front bumper, as well as their A series rock lights with 6 light. Found a website with Rigid products for 20% off. Plus their is a rebate through November. Still installing them. I'll let you know how they are once I get the switches hooked up.
I installed some Baja designs cubes and so far so good. Seem very high quality and plenty bright.
1 - 7 of 7 Posts
