just some stuff I have found that was posted in various places on the web...
Maverick 1000r Family Highlights
Industry-Leading Performance
» 101-hp Rotax 1000R V-Twin engine
» High-flow dynamics
» Intelligent Throttle Control (iTCTM)
» Dual exhaust
» Continuously Variable Transmission (CVT) with Zylon†-reinforced belt
» 10-gallon (37.8 L) fuel tank
Precision-Engineered Handling
» Double A-arm front suspension
» Torsional Trailing A-Arms (TTA) independent rear suspension
» FOX Podium X† Performance 2.0 piggyback shocks
» Mid-engine layout
» High frame rigidity
» 13 in. (33cm) of ground clearance
» Front and rear dual 214mm ventilated disc brakes
» 12-inch center-less cast-aluminum wheels
» 27-inch (68.6cm) Maxxis Bighorn† 2.0 tires
» Visco-Lok front differential
Driver-focused Design
» Driver and passenger advanced ergonomics
» Premium fit and finish
» Optimal seating position
» Removable free-standing seats
» Adjustable driver seat and tilt steering
» Passenger handhold and grab bar
» 2-inch (51mm) diameter, high-strength steel, ROPS-approved cage
» Quick-attach side nets
» 3-point seatbelts with anti-cinch
» High-strength, multipurpose rear rack with LinQ quick-attach accessory system
» 31.6 liters of cockpit storage
» Dual cup holders
» Multi-function digital gauge
» Digitally Encoded Security System (D.E.S.S.) anti-theft system, with 2 different keys
» 240-watt lighting
» 625-watt magneto
» Easy-to-use maintenance center
» Yellow plastic (base)
Can-Am Maverick 1000r X-RS Package Includes:
» FOX Podium X Performance RC2.5 piggyback shocks
» 12-inch aluminum beadlock wheels
» Analog / digital gauge
» Custom steering wheel
» X-package seat trim and graphics
Features and Benefits
101-HP Rotax 1000r V-Twin Engine
The new 976cc, 101-hp Rotax 1000R V-Twin engine is the most powerful side-by-side engine in the industry*. This liquid- cooled, single-overhead-cam power plant features four valves per cylinder and is fed by a 54mm Bosch throttle body and two VDO Seimens† fuel injectors. The sophisticated electronic fuel injection system automatically keeps the engine’s performance at its peak, regardless of temperature or altitude. Dual exhausts ensure that distinctive sound you’d expect from a high-performance side-by-side vehicle. The end result is a high-performance side-by-side vehicle capable of producing the most power, acceleration and best power-to-weight while at the same time maintaining excellent fuel efficiency.
High-flow Dynamics
When an engine breathes easier, it can produce more horsepower. So we optimized air intake, combustion and exhaust flow to improve engine efficiency. The result is the 101-hp Rotax 1000R. This was achieved in conjunction with increasing the flow volume of the intake plenum and independent intake runners that allow the tuning of each cylinder for optimal performance. A high-flow head to optimize the combustion chamber, thanks to larger intake and exhaust valves and an increased compression ratio (12.0:1), and high-flow dual exhaust all contribute to the more-powerful and efficient engine.
Intelligent Throttle control (ITC)
The electronic throttle-by-wire ITC system offers a smooth throttle delivery even if the driver’s foot is bouncing due to the rough terrain. The ITC system — which features a rider selectable twin-mode toggle switch for throttle control— can detect unwanted bounces and then filter the input, resulting in more throttle accuracy, especially at low speed. Drivers can choose between a progressive mode (standard) and a Sport mode, which offers linear throttle control. This system also reduces the number of moving parts in the vehicle; requires no maintenance; has no cables to adjust, lubricate, or replace; and the system has an increased life span.
Dual Exhaust
The dual exhausts uses tuned manifold lengths and resonator chamber to create more flow, optimizing performance and sound. Industry first catalytic converter and closed-loop system ensure optimal combustion from an emission standpoint, meeting new EPA/ CARB standards for 2014 models.
Continuously Variable Transmission (CVT) With Zylon-Reinforced Belt
The updated CVT system showcases a new belt reinforced with Zylon, a material with 1.6 times higher tensile strength and with increased belt rigidity in compression compared to a regular belt, keeping it cooler. A dual CVT exhaust design also ensures cooler belt temperatures, even in extreme conditions. A redesigned drive pulley with increased diameter will provide extra durability. Standard with engine braking to help slow you when going downhill.
10-Gallon (37.8 l) Fuel Tank
The Maverick has the largest fuel tank of sport side-by-side at 10 gallons (38 liters). That’s 14% more than its nearest competitor in the segment, providing extended range while exploring the outdoors.
Double A-Arm Front Suspension
The double A-arm front suspension front suspension features 14 in.(356mm) of travel for a capable and precise ride.
Torsional Trailing A-Arms (TTA) Independent Rear Suspension
The innovative TTA rear suspension on the Maverick 1000R is engineered to be compact, lightweight, efficient and deliver the performance sport enthusiasts demand. This is a compact version of a five-link suspension for no bump steer and the lowest scrub for optimized bump absorption and tire-to-ground contact. It also has less rear unsprung weight than other sport side-by-sides. The system features a double A-arm setup where each A-arm acts as two links and uses a toe-control link as the fifth link. The result is a more condensed and lighter package with less pivot points and spherical ball joints making it more durable because it reduces free play and wear, and is more resistant to undercarriage damage. Engineers designed the TTA to allow for optimal geometric weight transfer to enhance the tire-to-ground contact, while at the same time increasing its bump absorption, traction and, ultimately, overall control of the suspension. Offers 14-inches (356mm) of travel.
Fox Podium X Performance 2.0 Piggyback Shocks
The Can-Am Maverick features front and rear FOX Podium X Performance 2.0 HPG piggyback shocks with compression and preload adjustments so you can setup the ride to whatever playgrounds you choose to tackle. Re-buildable design allows for easy service and valving changes. This shock features dual-rate spring, high-volume 6-inch (152mm) piggyback reservoir, velocity sensitive damping control, hard-anodized aluminum body, forged piggyback body cap, hard-chrome plated heat-treated shaft, upper and lower bearing mounts, racing-developed high-flow piston and specially formulated oil for optimal performance at variable temperatures.
Mid-Engine Layout
The Rotax power plant sits low and close to the center of the wheelbase, which not only improves the Maverick side by side’s weight distribution and mass centralization, but also means it’s quicker to react to direction changes. The mid-engine configuration results in a low center of gravity and, along with the rest of the chassis components, improves handling while cornering. Add in a 84.3-inch (214cm) wheelbase and 64-inch (163cm) width, and the result is a nimble Maverick that is as predictable and confidence inspiring as it is powerful and dynamic.
» Dual exhaust
» Mid-engine layout
» Dual cup holders
» 240-watt lighting
» 625-watt magneto
High-flow Dynamics
Dual Exhaust
Mid-Engine Layout
