Damn that sucks. Your still under warranty correct?Just got back from the dealer. I guess the coil is bad, causing problems with ECU , and leaned out the front cylinder. Front cylinder is toast!! Only 80 lbs compression.
So what is happen with this? Warranty going to take care it?Just got back from the dealer. I guess the coil is bad, causing problems with ECU , and leaned out the front cylinder. Front cylinder is toast!! Only 80 lbs compression.
He bought a new one from the dealer. warranty will probably figure it out for him later.So what is happen with this? Warranty going to take care it?
