So I bought the Jensen stereo system for my maverick. I installed the system worked fine for the first ride. Second ride when I was warming it up the volume would go up and down, but only at idle. It works fine once reved up. I thought just a bad audio output cable from my phone. Well it isn't I also tried the radio same problem. Tried my XM using a radio station same problem. I checked all the connections they look good with my audio plugged into the input I can unplug the head unit, well you guessed it same problem.
What else can I check? Looks like the amp is cutting power to the speakers, only at idle when the engine rpm comes up it won't do it. Low voltage?
