I installed them, the front latch was fine but had to change the hinge bolt holes to make them work. I called and they sent a set of replacement doors thinking they were just drilled wrong but had to modify the new set also.Has anyone installed the factory canam doors? And did you have to modify the front mount that the door catch mounts to?
Thanks, I was trying to install the front bracket wrong. The directions are are not very good! They don't show a good pic. Now that I got them on I like them. The passenger side adjusted in perfect.The drivers side not as nice, could not get the front of the door to adjust up quite level. And there is not as much room between the door and the front plastic. I may modify the drivers side sometime down the road, to fine tune it in perfect. But they both open and close nice and do not vibrate or make noise.
I just got my Turnkey doors and plan on installing them tonight. Do you have any tips on the installation?My turnkey doors took two of us over 4-hrs...
But there right...
