I'm thinking of going this way. Looked at a couple pic's on the Stock Maverick (Yellow) and think that those same doors would like great looking on the XRS.Does anyone have pics of yellow turnkey doors installed on the xrs? I've seen the black and would like to see how the yellow match up on the maverick xrs before I make a decision.
??!When you get your rims powder coated, do you take the tires off? if so, is it easy to pull the tires off of the bead locks? I need to replace a tire on my commander bead locks but don't know whether I should take it to a shop or attempt it myself.
Yes you have to remove the tires as the the rims need to be acid stripped and the powder coating process requires baking the wheels at 400 Degrees. The only issue you will have removing the tire is breaking down the inner bead. If you do not have a bead breaker take it to some one that does.When you get your rims powder coated, do you take the tires off? if so, is it easy to pull the tires off of the bead locks? I need to replace a tire on my commander bead locks but don't know whether I should take it to a shop or attempt it myself.
Been doing it that way for years. Works like a charm.Easy way to break the bead that anyone can do is lay down some cardboard in the driveway, then lay the wheel/tire down with the bead you need to break facing up. Then lay a board down with one end on the ground and the other end on the tire right up next to the bead. Then have someone spot you while you drive your car/truck wheel on the board. As you drive up and put pressure on the bead it will pop off.
