1 - 5 of 5 Posts
I need j juan brake installation manual, could someone help me with a copy of the document.
2021 Maverick X3 RS Turbo RR
I think your best bet would be to contact J Juan directly or Vivid Racing for a copy of the manual.
From my experience, brakes are generally the same regarding installation from one brand to another. Was there a certain installation question that you had? Perhaps we can help...
I should have mine at home , I will look. The calipers should be marked LF, RF, RR, LR. since the piston bores are different you need to place them in the correct position. If i remember correctly the smaller pistons go on the leading edge towards the rear. The hardest part is the mounting bolts have a nut that goes between the rotor and the mount with a drilled hole for a cotter pin.
He got it and has no use for you or the forum anymore, not even a thank you. People these days are all take with very little give.
1 - 5 of 5 Posts
