1 - 9 of 9 Posts
Hey Glamisfan,
Just to let you know, that black bolt that is directly beside the hose is the head bleeder bolt. You will see the exact same thing on the other head. That is where you bleed the air from the coolant system/heads. The antifreeze you are seeing maybe from when they bled the coolant system, or that bolt maybe a little loose and leaking, or it maybe exactly like you said from the loose hose clamp. When tightening the head bleeder bolt be very careful not to over tighten. The part is plastic and has a tiny little felt washer. Just snug them up with an 8mm and you should be good.
You may already know all this, but figured I would share just incase.
Good to know info, Thxs
Discussion Starter · #7 ·
Thanks for the info WVXRS. I saw the coolant bleed procedure in the manual, but didn't pay enough attention to those screws. I could see the coolant trickling from the hose though. In the manual it says to bleed air from the coolant system, besides those 2 bolts, you're supposed to lift the front wheels of the ground 2', fill, run, then lift the drivers side 2' off the ground and fill, run, and check, or something like that!
1 - 9 of 9 Posts
