Since the tool we wanted to use is not longer made I came up with something quick on our plasma cutter we can make here to hold the primary. Wish we have a little more equipment to make one that holds both. That will come later so I will be cutting these out here using some 3/16 material and two 8mm bolts also have the can am secondary holding tool here as well. This is something just quick, easy and cheap that will do the job. Thinking like $15 I have to get some material first, the one in picture was cut using some 14ga which is on the thin side but it worked for prototyping.
