from another forum
Vss is located on the right housing of gear box behind actuator.To get at it remove pass seat side console cover and the fuel tank cover (plastic thing) it has a red wire,a white wire, and a black/green wire.
And.without a tiny torx bit and a wrench, your going to have to remove the 4x4 actuator which kinda sucks, and you'll have to refill your gearbox afterward as well if you remove the actuator . Gearwrench makes a small set that should do the trick, I got it at sears just so happens I left it at work when I did mine. I just followed the instructions in the shop manual, which I believe is still on this site somewhere....
Be sure to engage 4 wheel drive before removing the actuator. Then be careful to align the pin into the fork on the actuator. With the actuator in place, check to be sure 4 wheel drive disengages before you bolt everything back up.
