I have (5) 14" double HiPer double beadlock wheels with a 4+3 offset. Retail is $400 a piece, asking $200 a piece. These are double drilled and will except Can Am and Teryx bolts patterns.
I also have (5) 30x10r14 Maxxis bighorn tires, this are the 6 ply and have a stronger sidewall than the 2.0's that come from the factory. The rear tires have some wear due to tire spinning but the fronts are practically new with rounded edges. One sidewall has a tear in the rubber but holds air doesn't leak and was glued back together months ago and has zero issues. The tires retail for around $200 a piece, asking $100 a piece. No leaks in any of them!!!
I will NOT split these up.
I love these wheels and tires a swear by them. Stability is greatly improved by being 69" wide but I'm swapping race series and the tracks are getting smaller so I need to narrow up the machine. This is a killer rock crawling setup as the ground clearance, traction and stability can't be beat! I will do a package deal for $1250 plus shipping for the 5 wheels and tires.
