1 - 5 of 5 Posts
so i have a 2015 maverick 1000r and i have come across a problem with it going into limp mode after riding for about 10-15 min. if i shut it off and let it sit for a few min it goes away but comes right back after 10-15 min. sometimes it over heats at the same time but not every time. any help to steer me in the right direction to get the issue resolved would be greatly appreciated.
Discussion Starter · #4 ·
i havent had a chance to scan it yet but i will try both of those as well! thank you!
and yes the fan is running.
This model is known for trapping air in the cooling system. I had a 2014 model and it was very bad to splash mud up and clog the radiator. As Mega said use a light to shine through the radiator. Mine was so hard to keep the radiator clean I bought the BRP removable grill so I could properly flush the dirt out , it would look clean but if I held the sprayer to the radiator mud would keep coming out. If it is mud or dirt blocking the airflow you will most likely have to remove plastic or the radiator to get it clean.
1 - 5 of 5 Posts
