Hoping someone on here as some good audio knowledge. I am running a small PowerBass Amp with NO head unit using a Ipod and trying to set the amp settings to get the best sound out of my speakers. I am running 2 rockford M282-Wake tower speakers mounted on the cage. They are 8" speakers and I bought them to get the best all around sound without running a sub and hoping they would still produce some Bass.
My AMP can be set on LPF,HPF or FULL... LPF sounds horrible so I know they will need to be on HPF or full. HPF has a minimum of 80hz and when set on HPF at 80hz they sound good but do not produce quite as much bass as when on full. They do seem to be crestal clear and still have good mid range when set on HPF at 80hz.
To my knowledge when set on FULL there is no crossover filter being used which can be bad on the speakers?? I will give up a little bass to not harm my new expensive speakers if needed. Rockford lists the frequency response for the M282 at 48hz-22khz
If any of this makes sense any advice or suggestions would be great
