I bought another gauge to measure my belt temperature.
The old one was an analog gauge which I've replaced with a digital gauge.
Intellitronix Corp.
It came with a sender but no cable.
So I took a regular speaker wire and hooked the sense to the gauge to see if it works properly. Unfortunately it does not. Once I power up the gauge it shows 53 degree, it does not change if I hook up the sender to it and hold a flame under the sender. It stays at 53 degree.
Do I need a special cable to connect the gauge and the sender.?
I ran the ground wire to the motor block as suggested in the instructions.
The gauge has four wires coming out of it.
1 positive lead
2 ground
3 to sender
4 to light switch to dim
I connected the sender to the cable coming out of the gauge but the temp on the display remained 53 degree...... What am I missing here?.?.
Intellitronix Corp.
1 positive lead
2 ground
3 to sender
