1 - 14 of 14 Posts
Hello everyone, I appreciate any help I can get to detect and understand what the problem is.
Maverick xds 2019
Error codes:
p0106 p0235 p006d
Already Tried to:
reset ECM
Clean the Map Sensor
Replace the Map Sensor
Check for boost leaks
and problem reappear when the engine starts.
Can you think of a way to detect the problem?:rolleyes:
Welcome from Tucson AZ. Any decent dealers by you?
Reactions: Buskilos
those are sensor malfunction errors
check connections/ wiring or replace sensors
make sure your getting 5v to the sensors
they are not overboost errors
also there are two map sensors
the 4 wire is a temp-map
Discussion Starter · #9 ·
Thanks for replying,
The sensors are clean and have 5v ... Probably not the case
1 - 14 of 14 Posts
