1 - 13 of 13 Posts
check crank and knock sensor
what is a fuel pump code?
how did you check your fuel psi?
my manual does not list a p0323 code
fuel psi was 58psi in 17
went to 65psi in 18
not sure what the rr is probably 65
the og mav should be 58 so about 55 is as low as you should be
brp has been at 58 since about 03
you must be reading historical codes, not active codes
1 - 13 of 13 Posts
