Where do we find out pricing and more info on the reflash? I looked on your website and couldn't find it.
Here is what the reflash does:
raise rev limit to 8500rpms
Low range limit 8500 RPM
No speed limit in low range
No torque limit on acceleration ( halfshaft saver removed)
Race start (Throttle opening while cranking allowed)
FAN activation at 167°F (75°C)
Engine and air temperature limp limit raised (limp home at 248°F (120°C) only)
no vehicle speed limit
100% throttle in low range, no need for sport low mod, & gear position on display reads correctly.
Allow gas & brake at the same time
Right now, I have two tunes, 8500RPM rev limit, or 9500RPM rev limit, otherwise the same.
This will cost $500. to reflash your stock ecu to MRRPM race specs.
I can change timing, fuel, and have different rev limit, if desired, for $50. more
The ecu can be reflashed back to stock if necessary.
Also a thread on here:
http://www.maverickforums.net/forum/53-mrrpm/4502-mrrpm-race-ecu.html
