can the cats be jet hot coated?The cats are probably most of the problem as cats run around 400 degrees hotter then the rest of the exhaust. At least that's what I've personally found on cars, at 8000 rpm it may be more.
I personally wouldn't wrap the cats.
Yes the titanium wrap will go on easier and wrap tighter if you wet it first. The water makes it more flexible for wrapping. Cut it alot longer than they recommend so you can increase the overlap on the tight bends. That way it wont be short. Also, once you wrap it and clamp it let it dry completely in the sun before you start to spray the sealer on.Ok so even the titanium stuff we still need to get it wet for best easy application ?
