Does it not fit for either the front or the back or will it fit on at least the front or at least the back? I have one sitting around still in packaging that I bought from you guys for a commander that I sold and I would like to use it on the Maverick Max if possible.It does not. We are working on them today.
Simply ground the system out by wiring the two wires together on the drivers seat belt.Cool, is there a solution for the fasten seatbelt message once the 4 points get installed since we would be removing the stock harness and buckle? I also noticed power is cut if you ride without your seatbelt buckled..
It will not fit the front or rear sir, sorry.Does it not fit for either the front or the back or will it fit on at least the front or at least the back? I have one sitting around still in packaging that I bought from you guys for a commander that I sold and I would like to use it on the Maverick Max if possible.
