1 - 20 of 40 Posts
your grab bar is pushing down on it - or is the latch sticking ?
just pull up on grab bar
pull ur grab bar up does that help playdoh
weird mine shuts easy and opens easy never pops open
ya whats funny is there was 2 recalls to tighten the handle to so now its pushing on your glove box and they tighten it , lol
pull hard
My latch has never come open or anything like that but most times after I push it closed I still have to manually close the latch handle to 'lock it'. If yours won't even allow that I'm thinking the internals are hanging up and lots of cheap latches sometimes require just a bit of lube from time to time. Can you try and squirt a little silicone or WD40 in there and work the latch a few times and then see if it helps any.
That's what mine does. Mine will latch partially and I have to push the handle down to latch it fully.
Yea, I do the same sometimes but it still has a habit of poppin open rite when I hit a deep rut it a good golt but
U know what I have delt with a lot worse
X2!
Never noticed a problem with mine closing or staying latched. I have noticed it rubs or catches on the center console plastic
have any of u guys cleaned lubed the latch and pulled up on the stupid grab bar making sure its not touching the dash bottom that's pushing down on the glove box not letting it latch fully ? lol
1 - 20 of 40 Posts
