1 - 2 of 2 Posts
Has anyone replaced the bearings in the gearbox yet? I need to press them out and replace but some of the bearings are only open on one side. Suggestions on how to get those out without harming the case?
There are special blind pullers for this application. You could also apply heat to the perimeter of the bearing housing, as they typically fall out. Note you have to heat the case fast enough to not expand the bearing for best results.
1 - 2 of 2 Posts
