1 - 8 of 8 Posts
GEAR DRIVEN PERFORMANCE PORTAL GEAR LIFTS - SUPERATV
PGH-7-32-Can-Am-Maverick-Portal-Gear-Lift-1.jpg PGH-7-32-Can-Am-Maverick-Portal-Gear-Lift-2.jpg
We have kits for the following models:
Can-Am Maverick STD, XRS : 2013-2015
Can-Am Maverick XXC : 2014-2015
Why We Make Them?
Take back your torque with Gear Driven Performance by SuperATV. We all know monster tires rob your much-desired horsepower. To keep that ultimate performance and gain an extra 4” of coveted lift, you want GDP from SuperATV.
Why GDP?
The GDP portal lift system spares no details as the most comprehensive kit on the market. SuperATV knows suspension and transferred over 10 years of suspension engineering into the GDP portal lifts. GDP starts by vertically relocating the axle centerline while retaining factory steering geometry – a must if you want to increase the life of your axles, differential, and drive train components. Pair that with a 1.4:1 gear reduction (approximately 30%), and you’ve got a performance driven machine!
Performance
Pair with SuperATV lift kits, a arms, and axles for extreme performance
30% gear reduction
Designed for all terrains and riding styles
Axles
You will not chop your axles. GDP is the only kit on the market compatible with aftermarket and OEM axles with no modifications
GDP maintains performance-ready axle angles
Impenetrable Bearings and Seals
First in the industry thrust bearing that is specifically designed to take axial load, unlike the standard bearing that is only sufficient for radial loads
Automotive grade bearings
Press fit, precision ground gears and shafts to eliminate unwanted slop
Precision-Ground Gears: drive gear, idler gear and driven gear
Precision-ground chromium titanium alloy gears for industry best performance
Eliminates friction for reduced heat, noise and allows you to run at higher speeds
Reduced friction build-up
Quiet gears at all speeds
Performs at machine's fullest capacity
Steering Arm
Heavy duty structural member
10.9 grade hardware
Modular design for improved functionality
Aluminum Housing
CNC machined aluminum housing
Polished aluminum for long lasting, stylish finish
How About Adjustability? Pair with our adjustable a arms
GDP understands the need for adjustability allowing you to custom tailor your machine to match your riding needs
Eliminates unwanted, premature tire wear caused from misalignment
Camber adjustability on all SuperATV a arms
Mounting Plates and Pivot Blocks
CNC formed, fully gusseted 5/16” mounting plates
Forged pivot blocks
Slotted Rotors for Unmatched Cooling
Each wheel hub includes 4 bolt patterns 4/156, 4/137, 4/115, 4/110
Ability to utilize different wheels on same hub
Stainless steel, braided brake lines included in each kit
Requires a 14" wheel
1 - 8 of 8 Posts
