1 - 8 of 8 Posts
So I put to much oil in the gear box (like I always do ) anyways was wondering on this is it ok if there is a little oil dripping out of the check screw ? I didn't wanna let it run out till it was dry so it's a very small trickle coming out .
slightly over is fine…...
Reactions: kroth1984
always better to ask then to assume…..if it is too full, it will usually only get blown out the vent tube anyways but slightly over will not make a difference.
Reactions: bulldogs101
It is the plastic cap by the vent tube and gas tank....
Engine Auto part Fuel line Vehicle Motor vehicle
1 - 8 of 8 Posts
