1 - 10 of 10 Posts
Anyone out there running a fuel additive along with 91 octane in their Mav? If so, what are you using and what are the results? What octane will it boost to from 91?
I work pretty close to Beverly Hills and there is a gas station their that sells VP 100 octane fuel @ 8 big ones a gallon.
Thinking of picking up a few gallons for my ride next weekend.
Has anyone noticed any significant performance difference either running 91 w/ fuel additives and/or 100 octane fuel?
u do not need to run anything over 91 octane , do a search tons of threads about it
Same here mine runs great on 91oct I really don't think the higher oct will make much if any gains unless the machine is modded and tuned for the higher oct fuel IMO
u will not gain from much more octane , u will start to lose power , - only benefit from higher octane is it can keep pistons cooler , but our ECU programming is set to run off of 91 octane , 95 ron which in Canada is us its 91 octane !
The ticket would be to run 91 octane gasoline instead of the corn liquor concoction they force on us in good ol' California.
I add a little 110 to the 91 I run in mine - just cause I have it.
I'll probably just drop back to running the 91 once I use up all my 110.
Banned
I use Seafoam in mine but it's not an octane booster
100 octane made mine run worse then 91 so don't do it. I tried it when my rpms where all over the place and 100 amplified it..
I wouldn't do it. What ever small gain you think you'll get won't be worth it. These can-ams have to many gadgets to control everything, so I don't think it will do anything except hurt it.
1 - 10 of 10 Posts
