1 - 4 of 4 Posts
Anyone replace one of these.
There is a sensor wire connected to the banjo bolt at the MC.
Trying not damage anything in the process.
Can't seem to get the wiring harness detached from the car.
Anyways......
the wires dont unplug from the banjo bolt, look about 4” back above the steering column and you will find an inline plug.
Discussion Starter #3
Thanks Mega.
Yeah, I found the inline plug. Was able to disconnect it.
The issue is the side of the in-line plug that needs to be free has a plastic pin that locks it into place.
Looks like I will just have to force it out. Probably won't survive it, the pin that is.
Unless there is a trick.
It’s just a plastic barb that pushes through a hole in the steering column. Fork looking screwdriver pops them out easily.
1 - 4 of 4 Posts
