First oil change on 2022 X3 DS RR
13K views 19 replies 13 participants last post by  McCarthy
Just finished first fluid change on my 2022 X3, man what a pain. I did my oil changes on my old 2021 and they were not this difficult. The OIL drain plugs are just off center of a crossmember and the access hole on the skid plate does not line up with the drain plug as well.
I guess my hands are just to big to fit,,,!
Am I the only one or is there something I am missing,,, thanks!!
#2 ·
I have a set of FUTV skid plates that lines up properly with the drains, but can do an entire fluid change (trans, front diff, and engine) in under 30 mins. Just slide a paper towel tube through the skid plate until it's on the drain plugs, let it drain while you do the oil filter, and you're done, then front diff takes maybe 5 mins.
#9 ·
2022 they changed the cross member it isn't an issue with the cut out on skid but rather the cross member. I made a post about this.
