didnt turn out too bad. I bead blasted and painted the arms and springs then made my own aluminum exhaust heat shields. I also cut some large holes in them for access to the shock adjusters.
the passenger rear hub is off to replace a bent rotor. Its been ordered for 4 weeks now. And those damn hubs are on with blue loctite, i had to tap it off the whole way. It will go back on with a little neverseize for easier removal next time.
next up is the front suspension.
